show keychain
show keychain {keychain_name {detail}}
Description
Displays the configured keychains.
Syntax Description
keychain_name Defines a name for the new keychain. The range is 1-31.
detail Specifies a detailed output.
Default
N/A.
Usage Guidelines
Use this command to display the configured keychains.
The following is an example of the command's output with no specified keychain name:
# show keychain
                                    #        #     Accept
Name                             Keys  Clients  Tolerance
auth1                               3        2        10s
auth2                               4        0         0s
ospfv3-keys                         6        1         0s
The following is an example of the command's output with a keychain name of keys1:
show keychain ospfv3-keys1
Accept Tolerance : 0s
Number of Clients: 1
Key ID  Algorithm     Start Time            End Time                Duration
+1      HMAC-SHA-256  2021-06-01 00:00:00   2021-07-01 00:00:00     2592000s
 2      HMAC-SHA-512  2021-07-01 00:00:00   2021-08-01 00:00:00     2678400s
 3      HMAC-SHA-256  2021-08-01 00:00:00   2021-09-01 00:00:00     2678400s
Legend: (*) Active Key, (+) Selected Key, (Z) Time is in UTC.
The following is an example of the command's output with a keychain name of keys1 with detail specified:
show keychain ospfv3-keys1 detail
Number of Clients   : 1
Clients             : ospfv3-2
Key ID              : +1
Encrypted Key String: #$y2O9VBgcxFr4NkVKnadBL5y1s9cvnA==
Algorithm           : HMAC-SHA-256
Start Time          : 2021-06-01 00:00:00
End Time            : 2021-07-01 00:00:00
Duration            : 2592000s
Key ID              : 2
Encrypted Key String: #$f4Vtob4C5TdAs9Qf0w/pbB8RecE9vA==
Algorithm           : HMAC-SHA-512
Start Time          : 2021-07-01 00:00:00
End Time            : 2021-08-01 00:00:00
Duration            : 2678400s
Key ID              : 3
Encrypted Key String: #$bvE/wSf/6sztYL4wJw8ZUTWjJT2ZWw==
Start Time          : 2021-08-01 00:00:00
End Time            : 2021-09-01 00:00:00
Duration            : 2678400s
Legend              : (*) Active Key, (+) Selected Key.
This command was first available in ExtremeSwitching 31.3.
Platform Availability
